I have never had any problems with the drive before but this morning went to work on something and it just will not connect to my computer. I hear a ticking noise in the ext drive. Any suggestions, I don't know who I need to talk to about this.
If it's ticking, it's likely damaged. I know some hard drives have a high failure rate, and can die early.
One other possibility - the power cord / supply to the drive can go bad and cause the drive to 'tick'. To determine this, either try a separate power cord. But if you don't have one, listen to the 'boxey' part of the power cord, and see if it cycles - but typically with a higher pitch, not a click (the click can be caused by the faulty supply).
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
hope this helps you
