My LG Fuzzy Logic washing Machine (Model No. WF-T1022TP) is not functioning to its maximum. The drum is not spinning during any of the washing, rinsing or spinning cycles. However, it completes the entire cycle with the clothes wet but not standing in water. What could the problem be?
SOURCE: LG WF-T1022TP Fuzzy Logic
Dear Sir¨
The problem with my machine WF-T1022TP is the fallow:
The pump not run correctly, for these reason, I need the manual of operation, please send this document to my e-mail: [email protected]
thank you
Regards
Javier
SOURCE: washing machine
buy a new washer,the spider gear is gone probably from to much detergent,it's around 500 bucks for the part
SOURCE: LG WF-T552C The drum does not spin at all during
the timer you set when initially doing the wash is at fault if the other cycles spins as they should
SOURCE: my LG washing machine model-fuzzy
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
This is a very common issue and simple to fix, the height of your drain hose is too low, it is siphoning the water out of the machine once the water level gets up near the level of the drain hose.
Testimonial: "Thanks heaps. Will give it a try. Not sure if you can help with something else, there is a small leak from the bottom up the back. I have closed the outflow drain as tightly as possible but don't think it is related. Any idea what the leak could be?"
