The error code dH on your LG refrigerator is indicating a water supply problem. This could be caused by a few different issues:
Clogged or frozen water line: The water line supplying the icemaker and water dispenser may be clogged or frozen. This can prevent water from flowing to the icemaker and dispenser. Check the water line and make sure that it is not clogged or frozen.
Water inlet valve: The water inlet valve that supplies water to the ice maker and dispenser may be faulty or clogged. This can prevent water from flowing to the icemaker and dispenser. You can check the water inlet valve and make sure it is functioning properly or if it is clogged.
Water filter: A clogged water filter can prevent water from flowing to the icemaker and dispenser. If your refrigerator has a water filter, make sure that it is not clogged and has been replaced recently.
Water pressure: If the water pressure is too low, it can prevent water from flowing to the icemaker and dispenser. Make sure that the water pressure in your refrigerator is adequate.
You should first try to check the water line, water inlet valve, water filter, and water pressure. If none of these solutions work, please contact a professional technician or LG customer service to diagnose and fix the problem.
It sounds like there could be a few potential causes for the excessive water flow in your Bravos XL MVWB725BW0. Here are some steps you can take to troubleshoot the problem:
Clean the dispensers: Sometimes residue or buildup can cause blockages that affect water flow. Try cleaning the dispensers thoroughly with warm water and a mild detergent, then rinse thoroughly.
Check the water pressure: If the water pressure in your home is too high, it can cause water to flow too quickly through the dispensers. You can use a water pressure gauge to check the pressure and adjust it if necessary.
Check the water inlet valve: The water inlet valve is responsible for controlling the flow of water into the washing machine. If it is faulty or clogged, it could cause excessive water flow. You can check the valve for any signs of damage or wear, and replace it if necessary.
Check the dispenser hoses: The hoses that connect the dispensers to the washing machine can become clogged or damaged, causing water to flow too quickly or slowly. Check the hoses for any signs of damage or blockages, and replace them if necessary.
Check the control board: In rare cases, a faulty control board can cause water to flow too quickly through the dispensers. If you have ruled out all other potential causes, you may need to replace the control board.
If you are not comfortable performing these steps yourself, you may want to consider contacting a professional appliance repair technician to diagnose and fix the problem.
Your unit has a inlet valve that the supply of water flows to..This valve splits between allowing water to either the dispenser or the icemaker..This valve may be sticking open allowing water to keep flowing to dispenser..Google Model # w/problem to find location and part#..or call your local appliance repair company
The water flow needs to be checked,if the flow of water is very slow or no water is flowing then water dispenser will not dispense water.But water flow is checked ok then other possibilities like water valve and water line needs to be inspected.For more details.Click the link below:---
Hello there, when new filters are fitted usually they are expected to spurt for a little bit before they normalize and begin to flow properly. Dispense water continuously for 10 minutes. This usually arises when the flow of water through the unit not being allowed through properly and usually takes the new filter a couple of minutes to get accustomed to the water flow and get water circulating through all its components hence the spurts. Alternatively you can check to ensure that the water supply is turned on full and the filter is properly fitted. If all of these are in place then the dispense mechanism might be faulty. Hope this support has been helpful? Thank you for visiting FixYa.
Do the following:
Flush the water system. Use a sturdy
container to depress and hold the water dispenser lever for
5 seconds, then release it for 5 seconds. Repeat until water
begins to flow. Once water begins to flow, continue depressing
and releasing the dispenser lever (5 seconds on, 5 seconds off)
until a total of 3 gal. (12 L) has been dispensed. This will flush air
from the filter and water dispensing system, and prepare the
water filter for use.
Ensure that the freezer door is closed completely? Close the door firmly.
Ensure that the water shutoff valve is fully open.
Ensure that the water pressure is at least 30 psi (207 kPa)? The water
pressure to the home determines the flow from the dispenser.
Check for any kinks in the home water source line? Straighten the water
source line.
Check the water filter. The filter may be clogged or incorrectly installed.
if still there is problem of water flow then please take assistance of a technician to check the plumbing.
If the fridge is new and in the warranty period get in touch with the service center and ask for free service.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
Before you do anything, make sure that the plastic part in the bleach dispenser container is pushed in. Fill with bleach to the "max" line, written on the plastic part. Start the wash cycle and make sure that water goes into the bleach dispenser. Once water flows into the dispenser, the bleach/water mixture rises and should automatically dispense into the washer. We had this same problem. We removed the dispenser unit and took it to the sink. We then filled it with water and it started coming out from the bottom automatically. So sort of suction is caused from the amount of water and it starts to flow. Basically, you aren't adding enough bleach into the dispenser if the water flows into it as the wash cycle runs.
