I live in an apt building an someone has accessed my router settings an is stealing internet an Im getting viruses ..worms adware..I need to change my password .
To restore it to the factory settings press a paperclip into the hole marked "reset" for 5-10 seconds. Do that wile the router is on. Then if you need to set a special password you can connect to it and change the password.
To change the password connect to your router by going to your browser on your computer after connecting to your router. The default address for belkin is usually "192.168.2.1" for login its either "admin" or just left blank. there shouldn't be any password. After you login you can go through the settings and change your wifi name and password. Most routers also have many other security options like only allowing certain computers on that you add their mac addresses. Hope this helped. If you need more help just leave a comment.
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
SOURCE: lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
SOURCE: Can't access Belkin setup page 192.168.2.1 anymore.
There should be a small reset pin hole in the back of the device. Hold down the reset button for 15 seconds and it should reset the router to factory defaults
SOURCE: Belkin f5d8236-4 router to an access point and cant change back
On the side of the router there is a small reset key, that will restart it.. if you are talking about reseting the software then you have to get into the routers homepage. Let me know if that is what you are talking about and I'll walk you thru it..but the hard reset should do it..
SOURCE: Change of current belkin N150 password.
from the control panel update firmware to latest http://en-us-support.belkin.com/app/answers/detail/a_id/526/kw/n150/r_id/166
There ware a bug similar to this in the previous firmware version. Let me know if it works. Cheers...
