My Navman S50 3D (S55) has locked on iGO 8 after I tried running it from the internal memory. It won't boot from the memory card and won't appear on my computer when connected to the PC via USB. It will always boot back to iGO 8. If I tap iGO's exit button it will freeze on the shutdown screen. It won't either start navman software or windows ce. My idea was to clear it's internal memory so I can have the USB mode back again. Please help.
SOURCE: pin 570 wont boot after hard reset
RECENTLY I DID PRETTY MUCH THE SAME THING
SO HERE IS WHAT I DID :
" I TURNED IT ON AND HIT THE HARD RESET AND THEN LEFT IT ON TILL ALL P[OWER WENT AWAY FROM UNIT
SECOND I HAD TO DOWNLOAN A NEW VERSION FOR MY UNIT ; MEANING MAP
THEN I TOOK THE BATTERY OUT AND AND PLUGED IN MY USB CORD AND IT TOOK IT
I PUT MY BATTERY IN AND CHARGED OVER NIGHT AND WELL IT SEEMS LIKE A LOT TO DO BUT FROM WHAT I UNDERSTAND MY DRIVER GOT BOOTED OFF THE UNIT AND ANOTHER DRIVER FOR A MODEL WAS ATTACHED
HOW I DONT KNOW BUT MY UNIT WORKS NOW FOR THE LAST 4 MONTHS NO PROBLEMS
HOPE THIS HELPS YOU OUT RICHARD FROM CHICAGO
SOURCE: Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
SOURCE: navman s50
Try this link
http://www.activegps.co.uk/car-navigation/navman-s50/navman-s50.pdf
SOURCE: Error message on Navman Navman F
I have a similar problem, where did you download the firmware?
