SOURCE: what is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
SOURCE: HOBART AM15 DISH WASHER ERROR(E1)
are you sure you dont have a bad display, there are no e1 err. for the am15,e2,fill prob.e6sensor,ed,slow leak,ee, bstr not to temp.ef, iternal control err. if it displayed p1 that is an open or shorted wash thermister
SOURCE: How much water does my machine use per load. I
after initial fill, the mach. only uses 0.74 gal/rack
SOURCE: How do you drain Hobart
With the door lifted up, there is a lever on the rear-right on the inside of the dishwasher. Lift this lever and the machine should drain. If it doesn't drain with the lever up, remove the screens inside the dishwasher and verify that the lever is, in fact, lifting the overflow tube so that water can drain out the bottom.
