SOURCE: How can I boot from USB in a Thinkpad T22?
I assume with "boot menu" you mean the BIOS boot menu (the one you get
to if you press F12 during start up, before the Windows screen appears.)
Note: I am not 100% sure if you can boot from a DVD externally.
I booted from the internal DVD drive fine with a Linux LiveCD. It is
possible that the T22 BIOS does not support external booting. Check you
version - the latest release from IBM is version 16ET32WW (1.12),
release date 06/03/2004. You find that info here.
I would really appreciate if you could come back here and leave a comment, so I (and maybe others?) can learn form this ;-)
SOURCE: Owners manual ibm thinkpad notebook 2568 r32?
Try this link. Its pretty long so make sure you copy the whole thing.
http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=101256&brandind=10&doccategoryind=0&modelind=0&doctypeind=8&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49979&machineind=101260
SOURCE: ibm think pad r51 nodisplay 4 beeps commaing
This indicates a possible memory problem. Reseat the RAM modules and boot up, if OK then the laptop is OK.
If not then :-
If you have two RAM modules, remove both and insert one and boot up, if it is OK then repeat with the other one - this will determine which memory module is faulty.
SOURCE: IBM THINKPAD AUDIO DRIVER
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
