I need to remove cistern lid to tighten fitting. What do you need to do to remove ring around buttons ?
SOURCE: I removed the lid from my Duravit cistern. I
the botton should adjust up and down by tuning it left or right
SOURCE: cant get the lid off
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to left out the second button, then release the first button and pry that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
SOURCE: I have a Vitra dual
Have you tried to remove the outer ring by unscrewing it before you attempt to remove the buttons? I don,t think you should remove the buttons first.
