When I try to rewind bobbins it wind it sticks
Further to bluevelvet's post. The rubber drive ring has melted. A new one is cheap but it takes time to replace. Better to buy an independent bobbin winder than pay workshop prices of > $50 per hour.
To do it yourself is quite simple:
Next, WITH CARE , lever round the tray with a thin blade and use a small screwdriver to ease it out of the case; there are 2 bits that stick out more than the rest.
TAKE CARE NOT TO DROP THE SCREW INTO THE WORKS!. A piece of sticky-tack on the end of the screwdriver helps here if the screwdriver is not magnetized.
The bobbin winder mechanism is held in by 1 screw - take this out and you can then easily replace the rubber drive ring -(which you have providently ordered)
I took both my CS 8080s apart last week to replace the drive rubbers. The first took nearly 1.5 hours, the next 1 hour as I knew what I was about.
Check winder rubber is not damaged
SOURCE: sewing machine has bobbin thread would around winding shaft
If the bobbin is on correctly try crossing the thread before going through the tensioner which should solve this problem and also a more evenly wound bobbin.
SOURCE: Bobbin winder
then there is something wrong with the bobbin winder & it needs to be repaired
SOURCE: Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
SOURCE: Bobbin winder belt melted
SOURCE: Cannot wind the bobbin
