Bring your tv to your nearest distributor. because the it is a IC problem. probably the vertical section. Or just a cold solder in this area.( Vertical section)
This is a problem with the vertical circuit and is usually a defective vertical IC. If you can solder, locate the vertical IC (small flat IC attached to a heat sink with about 9-11 pins). Try resoldering the pins on the IC. If that fails to resolve the problem, replace the IC. This IC will be marked LA7837 or something similar. Keep us posted. Dan
