Computers & Internet Logo
Posted on Jun 08, 2009
I want an ethernet controller installer for my via technologies inc motherboard intel celeron (P4M266-8235). wHERE can i get it? There's no problem with audio and graphics. Only the ethernet controller is not working.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
923
Points
6
I have problem with my driver. help me
My wifi will not use my wifi router after upgrading ubuntu to ver 11.10 it worked before and i can use different wifi routers lspci 00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge 00:01.0 PCI...
first make sure your wireless adapter is not disabled you can check it by running rfkill list in terminal if it is type sudo rfkill unblock wifi [second you can try activating and deactivating by typing sudo ifdown wlan0 and sudo ifup wlan0 me personly have kept to 10.10 the 11.04 seem to have a few glitches you can also check for additional drivers
2helpful
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Sir,
    when u buy hp-520 ther must be a cd for ur sound control and ethernet control....
    if there is no cd,contact ur nearest service centre
    4helpful
    2answers
    Mother board
    Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
    Pros: None noted, given available product data.
    Cons: None noted, given available product data.
    Suitability: A compact motherboard, suited for small computers.
    Value: In view of its inexpensive price, this motherboard has great features for the money.
    Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
    XFXg31
    General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    2helpful
    3answers
    VGA Compatible
    this is the download link for the drivers
    http://www.soyo.com/product/Intel_Pentium_4/27/SY-P4X400_DRAGON_Lite/148
    5helpful
    3answers
    Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
    MSI has two boards P4M900M3-F, P4M900M3-L.
    Both of this will support your CPU
    Compatible board for P-4
    ok so its a 478 socket
    best board available is an asrock P4I65g
    Specification Value Product Description ASRock P4I65G - motherboard - micro ATX - i865G Product Type Motherboard Form Factor Micro ATX Dimensions (WxDxH) 24.4 cm x 19.8 cm Chipset Type Intel 865G / Intel ICH5 Max Bus Speed 800 MHz Processor 0 ( 1 ) - Socket 478 Compatible Processors Pentium 4, Celeron D RAM 0 MB (installed) / 2 GB (max) Supported RAM Technology DDR SDRAM Storage Controller ATA-100, Serial ATA-150 USB Ports Configuration 4 x USB Storage Ports Configuration 2 x ATA, 2 x SATA Graphics Controller Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0 Audio Output Sound card - 5.1 channel surround Networking Network adapter - Realtek RTL8101L - Ethernet, Fast EthernetView extended Specifications
    Please help me about my motherboard and the peripheral
    Hello, Noop!
    You should be able to download the drivers from the Foxconn product page here:
    http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=P4M800P7MB-RS2H&TypeID=en-us0000004
    Hope this helps!
    -thinstatic
    Top VIA Computers & Internet Experts
    MegaByteMe
    MegaByteMe
    Aron
    Steve Pack
    Steve Pack
    Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
