Require wiring diagram for xjr 1300 year 2010 (bike is australian purchase)
SOURCE: wiring diagram for bike
You can go to your local dealer and they usally will copy it out of ther service manuel for you.When you say passing lights do you mean highway lights?
SOURCE: clutch
Should be two small phillips srews holding the top on the clutch reservoir.Use tight fitting screwdriver so as not to strip these screws. Be very carful not to spill any fluid on your paintjob as this is probably brake fluid and will EAT your paint. If the fluid is clear it is brake fluid. If it is red it's tranny fluid...If you're losing fluid you most likely have a leak and should have it fixed. If you add fluid and the clutch still does'nt work you will need to do a proper bleeding......Good Luck to you !....Tim
SOURCE: how do i access the battery on my yamaha xjr 1300 2001 model?
if your bike is similar to an fj,you should lift the seat and battery is underneath in its own compartment to remove it,undo the rubber retaining strap the terminals and breather tube,battery lifts out vertically
SOURCE: I've a XJR 1300 but do not know the year model.I
Please visit this site and contact 'chacal' www.xjbikes.com
