2005 Hyundai Elantra Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change tke hood realase cable in hyundai elantra
How to change the hood realase cable in hyundai elantra 1998
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 146 Answers
  • Posted on Jun 08, 2009
Anonymous
Expert
Level 2:
Mentor:
Answers
146
Questions
0
Helped
46178
Points
494
Service and Repair Notes HOOD LATCH CABLE REPLACEMENT Remove the following items: Hood release handle. Radiator guard. Hood latch. Wheel guard. Using a clip remover, detach the clips from the body, then remove the hood latch cable (A) from the vehicle. NOTE: Take care not to bend the cable. Installation is the reverse of removal. NOTE: Make sure the hood latch cable is connected properly. Replace any damaged clips.
1helpful
I want to know if the motor on the 1998 elantra is a j1 modle or j2? Where can I look to see what it is?
The engine ID number is above the trans, printed on the block, below the head. There may be a emission decal under the hood showing a J1 or J2, if you call the Hyundai Parts dept with your VIN number they should be able to tell you.
1helpful
Hi We are installing an alternator on a Hyundai Elantra 1998, and need a diagram to tell us where the belts go. Help! Rick
Most of the cars their diagrams top of the Fan 0r the bottom of the hood
It is going to show you how to install the belt step by step so check your bottom
Of your hood or the cover of the fan
1998 hyundai elantra,i changed the fuel pump and and the relay and still nothing,help!!
When I put a Cd in the cd player it says error 42 Hyundai azera 2006
1998 Hyundai Elantra wagon shift lock sticks
dear friend-remove the cable from the gearbox,then move the gearshift to see if that is free.if that is free then move the link on the gearbox to see if that is normal.that should give you a idea of were the problem lies.
1helpful
Noise under hood like rattling sound
Try checking the heat shields on the exhaust pipe up front under the car. Alot of times they will loosen up, and begin to rattle. You can ither remove them, or try to clamp them.
Hope this helps!
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
