I my W3502, can I run both the 512 MB and a new 1 GB RAM stick?
SOURCE: RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
SOURCE: RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
SOURCE: can i upgrade memory more than 1 gb , standard 512
Sony specs say:
the answer is no.
If this answers your question, I'd appreciate 4 thumbs
Testimonial: "appreciate fast response, very helpful thankx"
SOURCE: I recently added 2 sticks of 1 Gb Ram to my
It depends on what you would like the end result to be. If you need to multi-task, and have 10 windows running at once, go with the 4GB @ 5300 because while it might take a little longer your computer will still be able to handle all the information. However if you are just using it for light browsing and would prefer speed over bulk (when it comes to data processing) go with the 2 @ 6400. I don't think it would be worth it to get 2 more @ 6400, technology is advancing so fast. If you have 60 bucks you can upgrade to two 4GB @ 10600 (8GB total for $60) 1333MHz PC3. Lookup Corsair XMS3 4GB RAM.
