Canon imageCLASS D320 Digital Copier Logo
A
Anonymous Posted on Feb 09, 2014
Black streaks on Canon ImageCLASS D320
Canon imageCLASS D320 Digital Copier black streaks
5 Related Answers
Anonymous
  • 69 Answers
  • Posted on Nov 26, 2007
SOURCE: Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Anonymous
  • Posted on May 03, 2008
SOURCE: With Windows Vista and Canon imageCLASS D320
imageCLASS D320/340 Printer Driver Ver.3.00 for Windows Vista
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=164&modelid=9036#DownloadDetailAct
old marine
old marine
  • 2426 Answers
  • Posted on Oct 16, 2008
SOURCE: Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Anonymous
  • Posted on May 06, 2009
SOURCE: Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Anonymous
  • 64 Answers
  • Posted on Dec 31, 2009
SOURCE: need linux driver for Canon imageCLASS D320
Here is the link to the driver http://www.linuxprinting.org/show_printer.cgi?recnum=Canon-PC-D320 I hope this helps
Testimonial: "thanks. I actually was able to download a good ppd for the printer direct from Lexmark."
Canon d320 service manual
Hello friend, you can find the canon imageCLASS D320 service manual in below link:
Canon D320 service manual:
http://goo.gl/fjS4rM
Thanks
How do i download canon imageclass d320 driver?
Click on the link below and then select your operating system to download the Canon D320 driver:
http://software.canon-europe.com/products/0000563.asp
1helpful
I have a black solid streak on my Canon D320 copies
Change the OPC drum cleaning blade and clean used the vacuum cleaner the development station.
1helpful
1helpful
2answers
Half of the paper is black and the other a normal
Problems in the scanning
You tried to print something?
Scanner Flat Cable fault requires replacement.
Part number HH2-3222-000
1helpful
2answers
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
2answers
On my canon imageclass d 320 Copies have 7 evenly spaced horizontal black streaks on them.
If what you are meaning is the streaks are not in the direction of the way the paper comes out - I would suspect it is on the drum or developer roller. Both items are part of the cartridge. If you roll the paper up to match one line over another and the end result is a tube about the sixe of a quarter - it is the drum. If it is the size of a dime - it is the developer roller.
old marine
old marine
ZJ Limited
ZJ Limited
