I have a 2003 nissa altima, car was last used lastnight, i tried to start my car this morning and it will not crank.(all lights/sounds on the interior of the car go off when i turn the ignition). After that, i am unable to arm/disarm the alarm system. If i continue to shut the door the alarm will eventually go off and i can then disarm it. I put the key back in the ignition, the lights/sounds on the interior of the car comes back on, I turn the key and everything goes dead again. I've tried the valet mode on/off, stood outside the car and armed/disarmed the system several times(when its working) and im still unable to crank my car.
You can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
SOURCE: Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
SOURCE: I have an Avital Tornado car alarm - it will arm
check on the bulldog security website for vehicle wiring color coding and discriptions. And the manufature web site for the units wiring outputs.
SOURCE: Prrestige Car alarm
press function (f) on your remote and Unlock at the same time for one second. as long as you have the two way remote it will work
SOURCE: I bought the car with wiper alarm system and
it may need to be programmed.......
-press the "f" button and hols for 12 seconds (ignore the beep at like 4 seconds.)
-press and hold the unlock button for 2 seconds...the remote should beep two times. each feature that is active will have an led light beside it. press the button to activate the feature. if the light is on the feature is on...
hope it helps...
