SOURCE: air compressor problem
Cheap oil-less compressor, normal.
If you don't like it, buy one that uses oil and a drive belt.
SOURCE: Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
SOURCE: Craftsman 3.5 hp portable air compressor keeps blowin head gasket
I would say the head or block is warped. Use Majic Marker to cover the mating surfaces , the head can be rubbed on a flat surface like a cast iron table saw to find the high spots, or the head can be rubbed on the block.
Careful work with a good flat file will remove the high spots.
The torque value sounds low even for an aluminum block, you could check with a small engine shop to get their opinion.
