Oven will not heat up fan still works and the grill
SOURCE: fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
SOURCE: oven fan works but no heat- grill works fine
It will be the oven element that has failed.
It is located at the rear of the oven compartment behind a removeable cover which will give you access to the element.
It is a straight forward job to replace.
Please rate my solution.
Thankyou.
SOURCE: my zanussi zbf360 will not heat up in the oven
hi it sounds like the fan oven element is faulty / expired.
regarsd
richard saupe
appliance repairman Colchester
SOURCE: Zaunssi ZBF360X built in Oven Not Heating
If the fan is working o/k, then more than likely the oven element has failed.
This is located at the rear of the oven compartment behind a removeable cover.
