AOC L22W898 22 in. LCD TV Logo
A
Anonymous Posted on Feb 09, 2014
Activate the menu lock.. please..
I want activate the usb port
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Jun 26, 2012
SOURCE: How do I activate the USB port on my Monitor?
Make sure it's plugged in to a USB port on the motherboard and check device manager to make sure the device is detected. Also might need drivers. If any disc came with your monitor you may wanna run that.
2answers
I want to activate my USB tv Port on that model, and cant .
This should be in the settings menu on your TV. Just like a computer you need to format the drive for the TV.
What are the steps to activate movies from usb port on my lg 50pg60ud model
50pg series cannot activate movies via usb
mainboard is not capable of doing that 50Pq series were the first to do this
The Pg series cannot play movies from Usb they have no processor for that
The first to have this were the Pq and then you could do this kind of hack
Sorry
Hi, I got this problem with my cellphone.. It
you have to activate your USB cabal port. you have to go to setting to activate
May 18, 2017 • Cell Phones
1helpful
2answers
How to communicate or activate my gprs?
hello beljohn,
i have some tips for your question hope this helps
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text "ACTIVATE" and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: "Sun GPRS"
APN: "wap"
Select SUN MMS
Account Name: "Sun MMS"
APN: "mms"
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: "Sun MMS"
Homepage: "'http://www.mmscenter.suncellular.com.ph"
Data Account: "Sun MMS"
Connection Type: "HTTP"
Proxy Address: "202.138.159.078"
Proxy Port: "8080"
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select "Sun WAP", Select "Edit Profile"
Rename Profile: "Sun WAP"
Homepage: "http://www.suncellular.com.ph"
Data Account: "Sun GPRS"
Connection Type: Select "HTTP"
Proxy Port: "8080"
1helpful
How to activate the gprs of nokia 1616
it depends on your carrier for Sun Cellular
Setup/Enable GPRS
Select Sun GPRS
APN: "wap"
Select SUN MMS
APN: "mms"
Setup/Enable MMS
Proxy Port: "8080"
Setup/Enable WAP
Proxy Port: "8080"
Mar 07, 2011 • GPS
20helpful
2answers
How do i activate my usb port on my sagem DTR94 HD Freesat
Can you please activate my usb port on my sagem DTR94 HD
1helpful
Activate usb port for my computer
you need to install update then windows XP to service pack 2...
The USB drivers are there in service pack 2...
15helpful
9answers
How can i activate GPRS and MMS setting for my china mobile phone
hi there,
here i post some procedures you can follow for activation your GPRS and MMS.
Text “ACTIVATE” and send to 2300
Setup/Enable GPRS
Select Sun GPRS
Account Name: “Sun GPRS”
APN: “wap”
Select SUN MMS
Account Name: “Sun MMS”
APN: “mms”
Setup/Enable MMS
Rename Profile: “Sun MMS”
Homepage: “’http://www.mmscenter.suncellular.com.ph”
Data Account: “Sun MMS”
Connection Type: “HTTP”
Proxy Address: “202.138.159.078”
Proxy Port: “8080”
Setup/Enable WAP
Select “Sun WAP”, Select “Edit Profile”
Rename Profile: “Sun WAP”
Homepage: “http://www.suncellular.com.ph”
Data Account: “Sun GPRS”
Connection Type: Select “HTTP”
Proxy Port: “8080”
hope it will help you to solved your problem or still you have any question regarding on it that you can't understand you can go on this site and log on.
http://www.kokeytechnology.com/gadgets/cell-phonesmobile-phones/how-to-activate-gprs-and-mms-of-nokia-phones-powered-by-sun-cellular/
Top AOC Televison & Video Experts
Arnie Burke
Arnie Burke
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
