I have a husqvarna viking Platinum 775 and the fabric does not advance. I cleaned out the bobbin area as much as I could, I changed the needle, re-threaded the bobbin and the machine,turned the machine on and off, all to no avail. Before it stopped advancing, I was using a walking foot and I heard a clicking sound and thought I needed to change the needle. Shortly thereafter it stopped advancing. Any suggestions? I hope it's nothing too bad. I want to get this quilt finished! thanks for your quick response!
Most of the time the bobbin case gets hung under the feed dogs, take your needle plate off and the bobbin cover there is a gray colored finger with a number 10 torx screw holding it in you can also try a small flat head screw driver, remove that finger and then remove your bobbin clean the hook out and replace the bobbin making sure it seats itself on the hook with the small notch on the bobbin case lining up with a small metall spring on the back right side of the hook area.
