SOURCE: Kodak memory card error
Hey hardygurl198,
What is most likely going on is you need to format the card so it will work in your camera. Every time you get a new memory card for a digital camera or if you put a memory card formatted to a different camera in a new digital camera you will need to format the memory card before you can use it. Directions on how to format your memory card are on page 27 of your camera manual, and I have provided a link to a PDF download of your manual in case you need it. I hope this helps!
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00431/C310_CD40_GLB_en.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Hi.
Enter main menu, scroll down to "Setup Menu" and then navigate to "FORMAT". Simply format your internal or external memory, and thats it.
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
SOURCE: have kodak easy share...how do i transfer pictures
After inserting your memory card into the camera, you should be able to transfer the pictures from the internal memory to the memory card. Choose the option to review your pictures and hit the menu button while reviewing the pictures. Within that menu, there will be an option for memory storage. Choose internal memory. Exit the menu and re-enter it while still in the review mode. This time, select the Copy To menu option to transfer your pictures to the memory card.
SOURCE: MY kodak easyshare c310 wont work
Take the pictures off the camera first and then format the card IN the camera.
