SOURCE: Low memory in my nokia 7610, how to delete some data (messages)
give it a soft reset then try to mark all th e messages and delete them for once
*#7370# then yes then 12345
u might need a memory card
SOURCE: memory low n70
You need to change default storage device on your phone, from phone memry to card memory. In other words, move all data (messages, songs, videos etc) from your phone memory to card memory.
for example, go to messages>options>other>momory in use - change it to memory card instead of phone. (if your memory card is not named, it will be displayed as NO NAME).
Do the same with other data also.
SOURCE: msg: Not enough memory Delete some data
It is due to ur phone's memory must be low.
just do the following steps
Go to Messaging->settings->other->memory in use and select memory card
this will solve ur problem
SOURCE: Nokia N70.sms sned and recv problem showing delete some data
try to reformat your phone first turn off your phone and press hold * 3 call sign and turn on your phone you must hold press those key until your phone is reformatted
SOURCE: Can not send or receive sms.though memory space is free 746Mb
Here "Not Enough Memory" Suggests either the SIM Memory is full or the Phone Memory is full. It has nothing to do with te Memory Card.
