It was not the circuit breaker, and the outlet has power. It just quit working during the heating of food and there is no time display. Model JVM192K003
Chances are that the thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
This can happen when the magnetron overheats, either due to it's failing, or if the internal cooling fan is not working.
It may also that be the 15- or 20A ceramic line fuse or the oven cavity thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very
helpful
when troubleshooting & testing.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
You should be able to
get the fuse from a home center or local appliance parts store.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
