Regardless of which key punched. the oven display shows a "6". Even non-numeric keys (broil, convection bake, bake) produce a "6".
The oven is 10 years old and has already had the touch panel and electronics replaced twice in ten years.
Model # JTP18WOA1WW
SOURCE: Electric convection oven keeps on producing heat
Probably a burnt out element shorting out to the frame. When the oven is on does the element glow evenly the entire length. Are there visible holes or pieces missing? The contactor could also be sticking.
SOURCE: Err on display when I try to set the bake temperature
Usually,
when an oven won't bake, it's because the bake element is burned out.
The bake element is the black, pencil- thick tube at the bottom of the
oven. When the oven heats, the element glows red. This element has an
expected life-span of several years. It may last for only one; it may
last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the
clock selector knob to OFF
2. “Tweak” the oven control by turning the clock
selector knob slightly to the left (counter clockwise).
This may stop the flashing message/beeping and clear the
display window.
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
SOURCE: Have new control panel installed. Top oven will
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
