Question about Konica Minolta C6500 C5500 C6501 C6000 C7000 Developer Set C/m/y/k Dv610
I have a jam 14 in my feeder unit.
I have a jam in my feeder unit, the number is 14. I can't pin point it, help.
  • Konica Minolta Master
  • 6,862 Answers
6ya staff
SOURCE:
I have a Canon D1120 and it says Check Document. There is no document in the feeder, no paper jams I can see... Any help? I tried turning it off and on, but got nothing
try to disconnect the feeder form the main unit and if still there is check document error then brother it is related to firmware(software)as i have encountered such in 3 machine before also but they were without feeder. so first disconnect the feeder connector from main unit .
Aug 18, 2011 | Canon imageCLASS D1120 Copier
Our copystar is creating a dark line on the right side of the paper
There are a number of things that can cause this problem, below are a few things you can try.
1. Remove the process unit out as if you were going to remove a jam. There is a green piece of plastic used to clean the main charge unit. Slide it to the left then back to the right. Make sure it is seated all the way to the right in it's home position or it can cause black lines.
2. If you have a document feeder on the copier is the line only when using the document feeder?
- Determine if it is by making a copy from the glass.
- If it is only when making a copy from the document feeder then clean the small **** glass just to the left of the large glass. This glass is used only when making a copy from the document feeder.
3. If you wipe your hand across the copy and the toner wipes off then fixing unit should be replaced.
I hope this is helpful,
Shawn
Feb 18, 2011 | Copystar CS-1500 Copier
Feeder is jammed
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 07, 2009 | Canon PC-980 Color Copier
Need to know on the 14 pin connector what color wire goes to what pin on a miller s-22p12 remote
I would go to www.millerwelds.com and download the owners manual based on your serial number. It will insure you get the correct wiring diagram for your feeder.
Aug 21, 2009 | Miller Welding Tools
Feeding paper for scanning/faxing - e-studio350
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
Mar 19, 2009 | Toshiba e-Studio 350 Copier
How to re-time the gears auto sheet feeder unit
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Pixma MP780 paper jam
Sandra, on the feed swich which way is the arrow pointing to the front feeder? or to the back feeder? Get a bright flashlight and inspect the back very carefuly. I had the same problem and found a label off of a shirt inside, don't ask me how it got there I havent a clue. But it did fix the problem. You can also try turning it on and off a few times.
If the arrow is pointing to the front paper feeder then the jam is in the front, if it is pointing to the rear that is where there is a problem. Hope this will help. Leo
Mar 15, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Jamming of documents in autmatic feed for scan mode
One way to unjam that would be to take a stiffer plastic or manila folder and insert it slowly into the document feeder and the slowly push it through the feeder until you dislodge the jammed document out of the bottom of the feeder.
That is a common practice in removing jams in the feeder.
Mar 13, 2008 | Office Equipment & Supplies
Hp officejet 7310
please check gear train and confirm no broken one-check of selonid not working in a right way and no foreign object droped inside(like pins).-check of smoth actuation of paper present detector.(in place and movement when you put papers
Mar 01, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Konica Minolta C6500 C5500 C6501 C6000 C7000 Developer Set C/m/y/k Dv610 Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
