On my 5701viper remote I can hit the f button 3 times and the unlock lights would flash 9 times.does 7752v have this feature?
SOURCE: got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
SOURCE: my viper alarm remote just beeps flashes TX and
Try to reprogram this. If this routine does not work please let me know and we will try something else
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
