Date is at 2012 and when I try to set it by the way I understand the manual the white date disappears and anotother display comes up. have tried many times of pussing right or left or up and down with sellector and get same results there is also the old time setting in tiny red nos. in lower right corner. appriciate any help you can offer
SOURCE: Toshiba 42H81 Rear projection "Convergence problem"
Also,check micro fuses F851,F852,etc.
and with a good digital meter, check resistors feeding B+ to
convergence circuit.
I have been using Stk392-110T made by Toshiba with no re-calls.Hitachi also has an upgrade IC.
And be sure to check your soldering of IC pins--good connect,
with no short.....T.
SOURCE: set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
SOURCE: need to set the date and can't find manual--
Try this:
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
SOURCE: date/time imprint. Coolpix 2100
To remove date imprint. This is the solution provided by Nikon more than a year ago. Switch on> set to green>menu>scroll down to Date Imprint.press centre/right on multi selector>select 'off.' Job done
SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
