I have Garmin Nuvi 660FM and used it for the first time for a couple of months today. After about 5 minutes on a new journey the screen changed and showed it was connected to a computer when it obviosly was not. I took it out of the cradle and reset and restarted it but it just shows the connected to computer icon everytime. I've tried a 'Pre boot' start up as well as the hard reset by pressing the lower right hand corner but no joy. Anyone have any ideas?
SOURCE: NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
SOURCE: Lost manual for Garmin Nuvi 660FM
Here is the Link to the Manual on Garmins Website.
http://www8.garmin.com/manuals/1262_OwnersManual.pdf
SOURCE: Garmin Nuvi 205 keeps saying no maps available ???
First you will want to empty your recycling bin & clear your
temporary internet files before re-downloading the Garmin_RMU_2010B.exe
file.
Below is the remainder of the fix I received from Garmin support
and it worked for my unit. Hope this helps.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
http://downloads.sourceforge.net/sevenzip/7z465.exe 32 bit
or
http://downloads.sourceforge.net/sevenzip/7z465-x64.msi 64 bit
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line add " -build_map_image 006-D0783-04 " at the
end of setup.exe". For example the end would look like xxx\Setup.exe"
7. Click Apply and OK.
8. Double click on the Shortcut to Setup.exe the map file will be
built. Leave the Window open till completion of all steps. 9a. Windows
XP: Click on Start>Run, then type in %Temp%. Another window will
open.
9b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
10. The file is placed in subfolder named 006-D0783-04.
11. Copy the gmapprom.img file from the folder to the Garmin folder
on the Nuvi. (Double click on MyComputer>Nuvi drive>Garmin
folder) Overwrite the existing file.
12. The Nuvi should now have the lower 49 installed. If you have
any trouble with this fix, or are not comfortable trying it please call
our Software Support Department at 1-800-800-1020. Please be at a
computer that has high speed internet access as we may need to log on
to your computer to resolve the issue. Make sure you have the program
extracted using the 7 zip program provided above. Hours of Operation
Monday – Friday: 8 am – 7 pm Central time (closed holidays)
With Best Regards,
Joyce K
Software Support Specialist
Software Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Joyce K
www.garmin.com
SOURCE: Garmin Nuvi 660 cradle socket is broken.
I called Garmin at 1-800-800-1020 and spoke to a customer service rep. Indicated I was driving down the road and the GPS fell out of the cradle socket...which the GPS could have broke. They said no problem and are sending me a new cradle socket at no charge. Good Luck.
SOURCE: nuvi® 255W Car GPS Receiver: The screen of my Garmin nuvi 255w GPS is white and...
Press and hold the lower right corner - then see second picture
