Question about Canon PowerShot A560 Digital Camera
Stuck lens cover on A560
My Canon A560 lens cover is stuck and will not open fully without help. I touch it with my fingertip and it opens. HELP!
  • Anonymous Mar 28, 2014
    Lens is stuck fully open
    Lens is stuck fully open.
  • Canon Master
  • 4,738 Answers
Please see the following article on automatic lens covers:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Jun 07, 2009
6ya staff
SOURCE:
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
The lens cover that opens when you turn the camera on gets stuck and you have to bump it to open it all the way
There is a little mechanical displacement in your gadget.. I personally thinks that you should get it serviced. coz that displacement is putting pressure on your motor. which may damage after some time...
Hope this has helped you... Please rate the answer.. Thanks.....
Jun 24, 2010 | Canon PowerShot A560 Digital Camera
Lens cover won't close and there is internal dust
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Gently slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
Apr 16, 2009 | Canon PowerShot A560 Digital Camera
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Lens cover is stuck
I did the same repair...however, I found that those little wheels are completely optional. All they do is keep the lens cover from prying away from the camera, but if you're careful, the lens cover will work without them.
Sep 07, 2006 | Canon PowerShot S45 Digital Camera
Canon PowerShot A560 Digital Camera Logo
2,297 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
