My trio stealth 4.3"tab will charge with the usb cord provided, but isn't recognized as a device on computer in order to download to it. The trio does not even read as if it's connected to a computer either, on multiple computers. It worked before. I've even tried the reset button.
SOURCE: not recognized by my Win XP SP2 computer
You probably erased some of the players system configuration files in the process of your file removal. You might want to reformat the device by going to my computer and right clicking of reforamt this device. Once completed you might want to unistall the device as well and make a complete fresh install of it by either installing the driver again using the players website download or the cd that came with you player. To unistall the device do the following: 1)Go to start 2)Right click on my computer and select properties. 3)Once there go to the device manager tab. 4)make sure it is connected 5)Find your device and right click and click uninstall. 6)After just restart your system and install the driver again for your player or insert the Cd another alternative would be instead of uninstalling is to check for a device update.
SOURCE: Computer doesn't recognize MP3 player -
I had the same problem, all you have to do is first turn on the Mp3.Then go to settings. Then go down to USB mode. It will probably say, auto detect.But instead scroll down to MSC. If that doesn't work try MTP.
Check My Computer. If the PC recognises the Sansa player then simply add the songs by dragging the files into the player's icon on My Computer. Sometimes this kick starts the built in software included on the mp3 player.
SOURCE: usb device not recognized when i plug in my zune
maybe the USB is rusty or dirty...it also happens to me
SOURCE: mp3 will not connect with my computer
I'm pretty sure I fixed a similar problem. Go to your device manager on your PC and uninstall the walkman driver. After this is complete just plug the walkman back into you Pc and the plug and play will download the driver again. This worked for me. My operating system is Windows vista.
