Haven't wantedd date and time on camera for long time and it is on 2012 and I would like to set it corectly but have tried per the manual and evertime I get the white date up and hit right or left it displys some else also shows the old date and time in red at lower left corner Thanks for any help you may offer
SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
SOURCE: Setting date and time on the picture
OK, I FOUND SOME INFO ON A WEBSITE THAT I'M GOING TO HOTLINK FOR YOU. SEEMS LIKE THE ONLY WAY YOU CAN DATE/TIME STAMP A PHOTO IS TO HAVE THE CAMERA IN THE POSTCARD MODE. YOU CAN READ ABOUT THIS IN THE WEBSITE I'VE LINKED FOR YOU. HOPE THIS SOLVES YOUR QUESTION, AND IF YOU NEED MORE HELP, REPLY TO:ARCLIGHT1217. IF THIS HELPS, PLEASE REMEMBER TO RATE THIS SOLUTION. THANKS!
http://www.imaging-resource.com/PRODS/SD750/SD750A3.HTM
GOOD LUCK!
SOURCE: everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
SOURCE: every time I set the date/time on my camera and
Replace the date/time battery on the side of the camera.
SOURCE: The time and date setting
CoolJoe72 only posted one answer, but it was a good one, and it applies directly to you. Check it out here: http://www.fixya.com/support/t313710-having_reset_date_time .
(The short answer is that you need to change the date battery, which you'll find under the terminal cover; it's a CR1220.)
