I replaced the control board and all fuses.It won't start on electric or propane.The on/off switch lights up and the auto/gas light shows electric and gas both on. Is there a reset switch? Any help is appreciated. the on/off switch comes on
You didn't say how old it is.
There is no reset switch.
you may have a defective control board, - presuming you replaced the defective one. the on/off light should respond if you turn it on or off - but the auto/gas light should not show that both AC and gas are powering the refrigerator. Contact Dometic for a new control board, and, if that doesn't fix the problem, you need a new refrigerator.
SOURCE: Model RM 2811 Dometic refrigerator
One problem may be high dc volts it should be around 13.5 max your convertor may be developing to much voltage. Relay is on dc side you have more than enough. The contol board would be your next check. Some places that sell them may be willing to check if you bring it in.
SOURCE: Dometic refrigerator will not stay lit
sand your thermal cupler off or replace it not centing the flam
