Hobart dishwasher model AMX900 starts operation by filling water and heating it during that its display led is read. When water reaches its level it stop water filling and its display become green to indicate that it is ready for entering dishes then it suddenly turns off. When I turn it on again the led indicates green for seconds and turns off again.
SOURCE: hygena dishwasher
there is a pressure stat but these are reliable. a common fault is the wiring loom broken where it goes round the corner at the bottom of the door. take outer door panel off and inspect the wiring loom for breakage
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
SOURCE: My dishwasher, a Whirlpool ADP
Hello & Welcome to FixYa
This light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
After this if the problem is back then check the door latch mechanism, if bad try replacing it. Please get back to me if you have any other questions.
Kevin
Testimonial: "A long overdue testimonial. It was as the expert said, the control board needed to be replaced. I was able to get one locally from a supplier of dishwasher replacement parts. And it worked as a breeze afterwards. I saved a lot of work, money, and environment by keeping the old dishwasher, which was not that old. 4 thumbs up, if only I knew where to give them."
