My Phone Says That SmartChip Is Rejected And Now I Cant Do Nothing! :(
SOURCE: nokia 6085 has a blue screen
^ WTF. That totally made no sense.
The nokia display on your phone is pressed onto metal contacts, as opposed to soldered like Siemens does. This results in a temporary/permanent loss of connection; bring the phone to a service center for your carrier, otherwise your out of luck.
SOURCE: I've tired to set the PIN code for my Nokia 6085 phone but I cannot.
Complete information :
The SIM card protects
your subscription and not the phone from unauthorised users. If you
change SIM cards you can still use your phone with a new SIM card. Most
SIM cards are blocked at the time of purchase. If your SIM card lock is
on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK
is supplied by your service provider. You can edit your PIN and select
a new four to eight digit number
To unblock your SIM card:
To edit your PIN:
To turn the SIM card On /Off
take the phone to a mobile service center and have the LCD replaced on the phone.
i have repaired this problem time after time you need to replace the flexcable which is located inside the phone between the top and bottom of the phone the problem is that these phones are very poorly made and the cable inside gets crunched up with opening and shuting of the phone its very easy to replace and change and with ebay you can find the cable for around 4 pounds inc postage if you need help opening the phone please email [email protected] i have had around 10 of these phones to fix and only 1 out of the 10 the screen needed replacing change the cable first its cheapest option! hope this helps all!
