Sansui a2000 integrated stereo amplifier dead right channel, power amplifier IC module is OK.
SOURCE: I have a Sansui AU-717
This company is not like they used to be. You can try the links below to see if you can find authorized service for your set.
Sansui:
http://www.sansui-india.com/
http://www.classicsansui.net/
Historic information about Sansui:
http://en.wikipedia.org/wiki/Sansui
I would personaly suggest to find a service center or a very good local tech who can do audio amplifier and reciever service.
Jerry G.
SOURCE: Blown Channel on an amplifier
Look for low valued resistors that may look ok, but be open. Check the emitter resistors (.22 or .47 ohms). Check the transistors in the driver circuit as well.
Dan
SOURCE: sansui au-G90x integrated amplifier connetcted
Dirth control switches and/or dirty/corroded/worn-out speaker relay.
SOURCE: I have a Fisher RS-717 stereo receiver, amplifier.
Yes you can use either A or B without a problem. The restriction is when you have both A & B connected. In that case, the speakers MUST be a minimum of 8 Ohm impedence. Using either A or B, you can use speakers of 4 Ohms impedence.
Dan
Testimonial: "Prompt answering, appreciate it very much."
most common on all such it dry joints on the main pcb.
all such items run pretty hot and after a few years one has to remove the main pcb and resolder all dry joints or complete pcb, to prevent resolder.
Best do the complete pcb to prevent future failures.
Colin 44ct357, audio fundi with 40+ years experience.
