Master
- Posted on Jun 07, 2009
Re: Wirefeed slips, i have the correct size o.9mm flux...
It sounds like the feed spool is too loose or worn out.There should be a tension adjustment. What wire size are you using? On those off brands they usually use .035. and make sure the spool is not dragging. The wire spool also has a tensioner, or should have, in the center. Good luck.
