A three pixel wide stripe goes from the top of my lcd all the way down, pressure at the top appears to affect the stripe, it started as a darker stripe then went to green, yellow after pressure, now it is purple, applying pressure/bending at the top point of the stripe appears to change the color of it
Hi Casey,
If the problem is getting worse, than either the pixels are dying (so to speak) or you might have a problem with the monitor's screen.
Unfortunately, if either of the above are true, then the only way to fix it would be to replace the screen, which can be quite expensive. If you agree that this is the problem then you'd be better off getting a new monitor instead of spending money to get it repaired.
Good Luck.
