GE XL1800 1100 Watts Microwave Oven Logo
A
Anonymous Posted on Feb 07, 2014
Buzzing noise a very loud buzzing noise that had to be unplugged because it doesnt stop
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
How do I stop the buzzing noise in my oven
You can open it n cut the supply wire or calltechnician cause it mist make noise whn its finish working
2helpful
LOUD BUZZING NOISE AND THE ANSWER I RECEIVED WAS FOR A DIFFERENT MODEL. CAN I FIX IT MYSELF?
If the loud buzzing noise is present when cooking food, the magnetron is the likely cause, some models are louder than others. But if the buzzing noise is there without the microwave running it should be checked. No! this something that should be checked by a professional for safety.
3helpful
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
1helpful
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
3helpful
3answers
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
1helpful
Buzzing noise, wont work???
The magnatron is shorting, overloading the high voltage transformer. From the picture this looks like an older unit and is probably not worth a magnatron replacement.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
