Seiko Melodies in Motion Clock Logo
A
Anonymous Posted on Feb 06, 2014
Can not find reset button on my clown clock - Seiko Melodies in Motion Clock
1helpful
Have 3 different melodies in motion whistle with clock 1 bag pipe player and a clown playing a horn all with corroded battery compartment where can I get those fixed?
this is just personal info maybe not the best info ...but if it were me i would use a little sand paper and gently clean the battery terminal (where the connection between battery take place) (careful of the wires) to see if that solves the problem
Dec 08, 2022 • Motorcycles
2helpful
2answers
My mother-in-law has a Melodies in Motion Clockpost Willie clock that she no longer has the instructions for. She can't figure out how to make him whistle. Can you point me to an ownder's manual?
Hello, Sherry -
I have not been able to find instructions online for the Seiko Melodies in Motion Clockpost Willie (a clown figure standing along side a clock on a post.)
The Melodies in Motion clocks are manufactured by Seiko Clocks. This is the link to the Seiko Clocks home page:
https://www.seikoclocks.com/
Near the bottom left of the home page, you will see the link to Customer Care. Click or tap on that link.
On the Customer Care page you will see the toll free phone number and the email address to use to ask if the instructions for the clock are available and how your mother can obtain them.
Best wishes.
Feb 23, 2018 • Home
How to test a cks
go on i'll bite what is a cks? is it clocks? A computerised kissing stick? A clown, a knight and a solicitor, walked into a bar. The clown fell over it, the knight jumped over it, The solicitor asked the clown if he wanted a no win no fee, claim starting.
My samsung washer has picture of a clown on it but will not do anything?
It's on child lock... hold down spin and soil level buttons at the same time for a few seconds it will go away and your washer will be right back to normal! :)
1helpful
I need to know how to set a Seiko Melody in Motion clock that I just purchased at a resale shop. It is working but the time is wrong. It is oblong with 4 clowns at the bottom. Thank you.
i had that clock hre. and all the insides are special from seiko, i would send it to them. the movement is encased in plastic and some lever rods attached to them . may be worth sending
2answers
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
6helpful
3answers
How do i switch off service now light on my vw golf 53 plate
Courtesy www.synthetic-direct.ca:
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button “A” located below the speedometer. Turn off the ignition while holding the button. “OEL” will display on the indicator. Press and hold the lower digital clock reset button or the analog clock reset button “B” until five dashes appear in the display.
If needed, next press the odometer reset button until IN 01 is displayed and then press the clock reset button until five dashes appear. If needed, next press the odometer reset button until IN 02 is displayed and then press the clock reset button until five dashes appear.
To exit reset mode, turn ignition switch on and when IN 01 appears, turn ignition off.
1helpful
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
9helpful
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Top Seiko Home Experts
ZJ Limited
ZJ Limited
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Seiko Home Expert? Answer questions, earn points and help others
