Just had above new heater installed. Fires up and works fine however "LO" error code is displayed when i turn heater AND filter pump off and place control to "standby". Once the filter starts again the "LO" error code goes away. Should this code be displayed at all times when both filter AND heater are off? This error code did not appear on old heater when system was shut down
"LO" is simply informing you that the Heater is not sensing proper water flow through it! It's a water Flow problem!
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
