My computer want come on its showing password error code and service tag code what should I do because I cant access anything
SOURCE: lost system password
Only way to remove a BIOS password on any computer is to remove all power sources from the motherboard so its memory can be cleared.
First, remove the main battery from the laptop. Then you must locate and find the little coin cell battery (It looks like a watch battery) on the laptop and remove it for about a minute or so. Then you can replace them in the opposite order.
Your coin cell battery is in a bay on the bottom of your computer. Enjoy!
1.
Before removing the coin battery:
2.
Locate the memory module cover on the bottom of the system.
3.
Use a Phillips screwdriver to remove the two screws securing the cover.
4.
Lift and remove the cover from the system.
5.
Locate the coin battery.
6.
Use a fingernail (or small flathead screwdriver, if necessary) to release the battery ZIF connector.
7.
Remove the battery from the chassis.
8.
Reverse the previous steps to replace the coin battery.
SOURCE: i cant unlock my dell
It's a weird key combination. I've done it before with a Dell tech on the phone but I can't remember how.
If you research it on Dell's site (which you probably did), you will see that they want you to call or contact them on Dell chat.
Info is here.
SOURCE: forget my hdd password on DELL 1537 hdd
Hi, your best bet is to go to the Dell website and enter your service tag in support page.
If you need more help, please ask.
regards - Anthony
SOURCE: need system unlock code for dell latitude
i can give master password
for any laptob dell or samsung or others
u can contact me on
[email protected]
