TV Picture is looking greenish. Ran troubleshoot: 1 Blink, Pause, 2 Blinks, repeats 5 times.
SOURCE: Mitsubishi WD-62526
Here's something that might also be useful. After you turn on
the set, and get the regular red blinky lights, hold down the Device
and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Testimonial: "very helpful. this was my first thought! thank you!"
SOURCE: Mitsubishi wd 65733: new bulb, 1 month ago, worked
The only thing that could cause the yellow light to blink after the new lamp is that the lamp lid or access door is not placed correctly or there might be some debris between the door and the door seat to where the door sensor switch is not being activated or the switch is erratic. Try using some compressed air to clean the switch and the door seat, that might do it for you. Thanks!
