Windows xp sp2 1gb very slow
SOURCE: Copy of windows setup cd
If you want to get it legally, then go to a store and get it.
If you want to get it illegally, then download some torrent file and burn it in a CD. make it a bootable CD. but you cannot be assured that you will get the product key in all the torrents. try various torrents and get the right one.
~regards,
Jegan
SOURCE: Windows won't start, need copy of windows setup cd
Windows Xp Cd is same for all the processors.It depends on you what you need to install,
You can buy in market and they will charge 400 bugs at a max.
If you belongs to hyderabad, i can give a copy of it
SOURCE: Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
SOURCE: I HAVE NO SOUND DRIVER
Go to Compaqs web site and download the Win7 driver for your sound firmware and install it. Ensure you specify either 32 or 64bit. Check your OS for the specification.
Hope that solves your problem.
