SOURCE: no more illumination
It's dead sorry to say.
We have owned several of them in the past and the manual itself is NO help.
We have tried to call Olympia and Sharper Image and still no help.
They have a very short life span, unfortunately.
The only thing that you might be able to do is, unplug the unit for about an hour or so, and plug everything back in. It may reset itself.
SOURCE: Olympia, and/or Sharper Image infoglobe. Need fix.
It appears that you have already removed the 4 screws. The globe will not just fall off, it has to be pried. Take a small- bladed screwdriver or a small-bladed pocket knife and gently pry from any small opening you see between the globe and its base. Work the blade around the globe and it will come off. I just did it and now I'm trying to figure out how to get inside the "guts" of the globe. Will keep you advised.
SOURCE: Olympia Globe Caller ID
I just printed a manual in pdf form go to,http//smarthome.com/manuals/5109.pdf
SOURCE: Sharper Image Info Globe Scrolling LED Message Center Mod# W1701
what happens wen my globe does not light anymore ?
