When i push the power button nothing happens but timer light will flash
SOURCE: mitsubishi vs-5052 tv
as you are not electronic person so call skilled person. problem is simple. 1 there might be in power supply. 2 if power supply is ok horizontal section might be defective
SOURCE: MITSUBISHI TV VS-60607
Do you get any power indicators? it may be a problem in the powersupply area, or something more serious. Start with checking the fuses there.
SOURCE: Mitsubishi vs-60607 code 24
Here are the two top reasons that can cause the 60607 to throw a 23 or 24 code. Check these items then let me know what you find.
1. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
SOURCE: mitsubishi vs 60607 circuit board
this isn't a notorious problem. many problems can cause this. the instant on/off behavior just says there is one of many fuses blown in the television. you can't just replace the fuse, when it fails get a failure code find out what it means and repair the problem. I would recommend paying someone to do it if you don't want to trash your mits set.
to get the code you hold down the menu and input button for 5 seconds after the on/off sequence. it is a 2 digit code with a pause inbetween, example 2 pause 2 pause 2 pause etc. is a 2.2 code
