Have input all recommendeed settings for direct thermal print however refusing to print. even a config label report spits out 2 labels then stops... help!
SOURCE: TLP 2844 skips over labels
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
SOURCE: Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
SOURCE: 2844 UPS Printer Prints Duplicate Labels
The quick and simple answer is to use a different driver instead of the 2488 driver that UPS provides, that is where the problem lies..
Under printer properties, Advanced Tab, I changed the printer driver to Zebra S4MDT-200dpi and now the printer works fine. Prints labels correctly, and most of all only one label at a time... The drivers are there in the UPS software, just change which one you use and go...
John Plemons
