Bosch Nexxt 500 Plus WFMC5301UC Logo
Posted on Jun 06, 2009
Motor turns but very slow
I have a problem with my washing machine hwf800x.the control seems not working as its supposed to be
  • rainadam Jun 08, 2009
    thanks Maael. but i have tried selecting everygiven opotion. even spin as well. but it got its own programming seems like the motor rotates the same speed after the motor got stucked dou to breakage of one arm which holds the drum and the saft. we repaired the arm but after thateverything has been changed.
Anonymous
Level 1:
  • Contributor 132 Answers
  • Posted on Jun 06, 2009
Anonymous
Contributor
Level 1:
Answers
132
Questions
0
Helped
42472
Points
10
You maybe choose a wool programe it seems to be like that pleas try 1st to select a cotton program
3answers
Aiwa AV-X200 Stereo Receiver volume knob: When using the remote, the knob isn't spinning correctly any longer (doesn't spin, or spins really slow). Take the unit apart? What should I look for?
Question edited for clarity.
Question moved from Washing Machines category.
Check out the video. It may just need cleaning with switch cleaner and a couple of drop of sewing machine oil. The fact it does move is a good sign.
https://www.google.com/search?q=aiwa+av-x200+volume+control+not+working
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Hi, the machine only works for like 5 seconds before it stops and the beeping sound comes on. Its the same for any mode (wash, rinse, soak, spin). The water works fine, only that the machine stops and...
MAybe the motorr is on an overload, check to see if the motor is heated and running slow, check the capacitor, replace and test. Check if there is friction on the spindle. Finally the programm controller by itself can be a suspect if all the above seems OK.
Will only spin slow speed will not spin at high speed. Everything else seems to be working fine.
Make certain that your selected wash cycle designates a higher spin speed. If so, then you may have an issue with the motor or motor control board. Contact an appliance service company.
Kenmore washer not spinning well (very slow) with or without clothes leaving clothes wet after full cycle. I also noticed a faint burnt rubber smell and a screeching sound during the spini cycle. Note: I...
It is much harder to turn the basket with the motor shaft. If it is not getting up to speed the brake is dragging and the basketdrive /brake will need replaced.
Eric
House circuit breaker trips when machine is set to delicate wash
Motor controller or motor itself has a short.
OR something stuck in the pump impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Heavy Duty Speed Queen top loader, HA 4011-3062, with a slow spin
I have a related problem and I just learned on the net that the Vbelt is supposed to slip in "idle" mode while the water pump will do more work.
It is also supposed to slip slightly while speeding the spinning up so as to not cause motor overload.A kind of half clutch function that allows for slipping. This slipping is controlled by the tensioner.
My guess is that your machine's v belt slips too much and thus does not spin fast enough. You replaced the belts, I would look at the tensioner now.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
