SOURCE: Dell Inspiron Mini 10 Not Shutting Down Properly
There could be a corrupted file. I would try to give dell tech support a call
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
SOURCE: my dell inspiron mini 10 won't boot.There is just
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else. I've removed the battery and unplugged the unit and put it back together and it still does the same thing. HELP!
SOURCE: How do you change the
The easiest way to change wallpaper/desktop background is open the picture/photo, right-click and "Set as desktop background".
You can do it from the personalize options available in display settings. Right-click on the desktop, select "personalize" and click "Desktop Background" from the available lists and browse the picture/photo you want to set as desktop background.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
