SOURCE: oven door will not close completely no
I told bosch which is the same as siemens that the door hinges are defective. I even told them how to fix the problem without changing the hinges .If you add three washers on each hinge this will bring the door in to close the same for the bosch ranges. ps ex tech:)
SOURCE: dacor wall oven model# MCS130S door won't close.
sorry this is a common fault with them you cant fix it i have tryed in the passed
SOURCE: oven door won't close.
sorry i have tryed to fix them in the passed they cant be fixed need a new door sorry
Hi
The door
lock assembly is bad and should be replaced, you can try to move it but that
won't help and will have to be replaced to solve this issue. Hope this
helps...please post back for further assistance.
Daniel
