When you put the tape in and play your songs,then take it out or eject the tape, push in the radio mode, you should the radio , if not check to make sure you got a good antenna connection, sometimes there maybe a delay but hopefully not two minutes, should be more like 5-10 second delay
Look for a switch or button with the word "lock", or a picture of a key... Push button, or flip switch.. If that doesn't work remove batteries, wait 10 min. replace batteries.
you probably have your amp hooked up to your power antenna remote. there should be another blue wire (probably blue with a white stripe) that is for amp remote.
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
If you Right Click on the Speaker icon in the lower right screen (system tray) and choose Open Volume Control, are all the slide levels about in the middle, and no check-box is set to Mute.
did your battery die after you installed cd player or did it die because of some other reason. please first confirm this since wrong connections are the biggest culprit .best of luck.
other than just double checking your switches settings there really isn't much you can do ,as there really isn't any easy to replace parts inside and that would be cost prohibitive anyhow , but do remember it is a clock radio , if its set t o use the alarm the radio will not work and not the cd either , ck all your switches for proper setting , one may have got bumped by you or cleaning staff
this is the reason I use a sound bar/phone dock as I use it to charge my phone and play music all day at my desk , they only cost about fifteen bucks to buy , and best thing is there's nothing for anyone to mess with when im not there as it wont work without my phone docked in it !!
